Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-24-2009, 04:24 PM
wolfer1955 wolfer1955 is offline
2002 firebird 3.8l dies instead of accelerating.
Go to merge on the freeway and instead of usual acceleration car dies. Towed home. Clean positive battery cable (in bad need of) and install new battery. Go to work in the am and same happens again on entering the freeway. Any suggestions.
Old 09-24-2009, 05:15 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Re: 2002 firebird 3.8l dies instead of accelerating.
check your maf sensor, or the vaccum line its on it.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 09-25-2009, 10:21 PM
IROCmenace IROCmenace is offline
If you 3.8 is lilke the 5.7 in those cars the thorttle body is controlled by a electic stepper motor, not a cable like in older cars. CHeck your thorttle boy and make sure it is not cable controlled. If it is not then it is "fly-by-wire" GM went to this around 2001 in F-bodies. You need to take the MAF off so you can see the throttle blade and have a buddy step on the gas with the ignition on and make sure the blade opens smoothly with operation of the gas pedal; if it is jerky or has dead spots that is the problem; if it works you can move onto other diagnoisis.
