Old 09-24-2009, 12:04 PM
badpoor badpoor is offline
96 Wagon Axle
I'm trying to replace my left side axle and it does not want to come out.
no prybar worked and I did take the transmission cross member off.
I have bent countless prybars trying to attemp to get this thing out.
Would it be bad if I took the other side out and knocked the drivers side end out through the tranny case?
Old 09-24-2009, 12:21 PM
zzyzzx2 zzyzzx2 is offline
Re: 96 Wagon Axle
Sure, just make sure that whatever you use can keep the differential from dropping.
Old 09-24-2009, 07:18 PM
12Ounce 12Ounce is offline
Re: 96 Wagon Axle
NO!
You will destroy the tranny if you try to go "through" it .... there ain't no way! (Unless there is something different about your tranny compared to the several automatics that I've worked on.)
Keep laboring with the side that needs to come loose. I know it can be a miserable task ... and you will think the axle will never break loose ... but it will!
TIP: I have use tapered wooden shims, driven in place, to put some force on the axle hub ... and then with a crow-bar in another spot on the hub, broken the axle loose. I don't know why these things have to be so difficult. My Windstar's axles just "fell out" in comparison!
Old 09-24-2009, 08:17 PM
FordMan59 FordMan59 is offline
Re: 96 Wagon Axle
They will usually break loose easier with a quick jolt than if you just try applying lots of pressure. I've read of lots of people having trouble removing these axles, but I've never had any problems. Knock on wood!! I think the last time I removed them in my '88 Pony I used a flat 12" carpenters pry bar and it popped right out. I think there is also a tool that can be used with a slide hammer to remove them, but I've never seen one so I don't know how it works. Might check with some of the auto parts stores and see if they have one in their loan a tool supply.
Old 09-25-2009, 08:58 AM
Re: 96 Wagon Axle
Old 03-10-2010, 07:31 AM
Re: 96 Wagon Axle
That tool above will never work properly
there is not enough room between the axle and differential housing to get it completely on.
I had a bad axle on this car and it was totally defictive(thanks advanced autoparts!)What it came down to for removing this axle and everyone should read this was, I need to get a fairly small pry bar and put it through the passenger side of the tranny. the prybar has a bent tip wich will give you clearence underneath the differential pin. all you need to do is place it against the shaft and use a hammer and tap it a few times above and below the pin.
NO AXLE WILL EVER GIVE YOU AN ISSUE AGAIN!!!!
REMEMBER: DO NOT REMOVE IT COMPLETELY UNTIL YOU PUT PASSENGER SIDE HALFSHAFT BACK IN!
Old 03-10-2010, 08:22 AM
Re: 96 Wagon Axle
What brand axle was this from Advance Auto Parts and was it new or rebuilt? Personally, I use the rebuilt ones from NAPA.
Re: 96 Wagon Axle
I have to admit that I had wondered about that.
