Old 09-23-2009, 06:05 PM
kz0129 kz0129 is offline
2001 Silverado, suddenly stalls. Fuel, no spark
My 2001 Silverado, (3/4 ton 6.0L gas, 91,000 miles) had died on me the last 4 times I have driven it. Originally I though it was a fuel delivery issue, but I have fuel. ( I haven't checked the pressure, though). It will run for 10-15 minutes then die suddenly. turns over just fine, but will not start. Fuel pump is turning on, have fuel in the rail. Until today, it would finally start after 30 minutes -1 hour, but today it is still not running after 1+ hours.
Help!! I am hoping for a non-costly fix, out of work and this is not a good time for a several hundred dollar repair.
Thanks for any suggestions.
Old 09-23-2009, 08:47 PM
j cAT j cAT is offline
Re: 2001 Silverado, suddenly stalls. Fuel, no spark
with no DTC this could very well be the crank position sensor...with no pulses coming from this no spark will be commanded...
it is located under the starter motor..check wires connector ,replace...sensor...these I have seen fail after they heat up..intermittent low output failures..
checking the fuel pressure is needed with a pressure guage !
Old 09-23-2009, 09:38 PM
would a crank position sensor failure act differently than a cam position failure?
Old 09-24-2009, 08:59 AM
I never seen or read any failures with the cam sensor..maybe a forum member can respond to that one..
but as I stated before the crank sensor is a possibiliy...
any DTC's ? exact fuel pressure ?
Old 09-24-2009, 06:58 PM
I've got to get a pressure meter from AutoZone, but their seems to be good pressure at the schrader valve, it comes out with some force, not just dribbling out.
I climbed under there today, I can't see anything behind the starter, although I see wires that go back behind the starter. Would I have to remove the starter to replace the sensor? are their any tricks to getting to the sensor. Sorry if these are stupid questions, I've not done this before.
What is DTC? (check engine codes??)
Old 09-24-2009, 08:32 PM
dtc /check engine codes. must remove starter for access to the crank sensor...must have pressure of fuel [squirts pretty good is not correct] pressure gauge required..53-62 psi...if below this range and the fuel pressures drop rapidly on engine shut down pump is most likely n/g...
Old 09-25-2009, 12:31 PM
Fuel pressure is 55psi. Has 2 codes, is this order:
P0300 - random multiple cylinder misfire
P0335 - Crankshaft position sensor A circuit malfunction.
I'm going to go ahead and buy/install the crankshaft position sensor. It seems logical that the malfunction is a result of overheating, it runs for a while, shuts down and will only begin running again when the engine has cooled off.
I'm going to assume the 0300 code is a result of the 0335;
Thanks for your guidance. Hopefully this fixes it.
Old 09-25-2009, 05:17 PM
she's running great, but I still am getting the P0300 code. I'll try changing the plugs and see what happens.
Old 09-25-2009, 08:26 PM
thats great this all is in line with my cranksensor failures...
next is replace plugs and get oil changed...this should do it...don't want all that unburned fuel to contaminate the oil then damage the engine...
Old 09-25-2009, 08:46 PM
Will do, thanks again for all your help.
