Old 09-23-2009, 03:04 PM
happydog500 happydog500 is offline
5 Quarts oil way to much?
I just changed my oil and filter. I put in 5 quarts. I check the oil (both then and after running) and it's way over the full mark. It goes all the way up to the twist in the stick, more then a full quart over.
My two manuals both say 5 quarts with a filter change. What happened?
I know it can look higher, but not. One side is a little misleading. I can tell where the oil is, and it's way to high.
How is 5 quarts with filter, way to much?
Thank you,
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 09-23-2009, 03:39 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 5 Quarts oil way to much?
Did you clean the dip-stick with a paper towel before checking?
Old 09-23-2009, 03:48 PM
C man C man is offline
My manuel says 5qts also. Seems to be a debate on 4.5 qts or 5qts. I put 5qts in mine and its always dead on the full mark. I did an experiment by just putting 4qts in and checked the dipstick then put .5qt in and checked again still had to holes left. finished topping it it of and it filled the last 2 holes. Maybe its the dipstck. My oil dipstick has no twist in it though. My transmission dipstick does. The trans fluid was way over the full mark when I got it. Was concerned at first but 50k later and two pan drops, trans still smooth I don't care if its past the full mark.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 09-23-2009, 06:13 PM
Yes. Maked me scared to think how overfull it is.
If I put in 4.5Q, the way it is now, it would be overfull.
Chris.
New Balance 662
Trek 8000
Old 09-23-2009, 06:35 PM
I went to the store, when I got back I thought I would check it before the oil drained back into the pan.
I took a picture. Here is what it looks like.
Chris.
New Balance 662
Trek 8000
Last edited by HotZ28; 09-23-2009 at 08:51 PM. Reason: Original pic too wide: 1509 X 842!
Old 09-23-2009, 06:59 PM
Interesting. 4.5qts should come up to the 3rd circle in the hatch area at least in my observations. 3.5qts of oil would be right under the hatch area.
Old 09-23-2009, 07:28 PM
If you look at the left side of the picture, where it starts to curve, if I let it sit for a while, it will go up to that.
Picture is the lowest it gets.
I like stuff on my car to be right. This plays with my mind. Chris.
New Balance 662
Trek 8000
Old 09-23-2009, 08:40 PM
HotZ28's Avatar
AF Moderator Elite
When you check the oil level, was the car sitting on level ground? My Series II engine calls for 4.5 qts with filter change, if I added an additional 1/2 qt, the dip-stick would look just like yours. Anyway, here is an enhanced picture of your dip-stick.
Old 09-24-2009, 12:56 AM
I wonder a 2.2l ecotech engine has a 5qt sump and a 3.8l 3800 engine has a 4.5qt or 5qt sump variation, it seems. Any insight or thoughts on this.
Old 09-24-2009, 07:22 AM
polarzak polarzak is offline
Is this the first time you changed your own oil? If not, how much did you normally put in and what was the dip stick reading then? 4.5 quarts to 5 shouldn't make a huge difference. Maybe they were Canadian quarts. LOL
Old 09-24-2009, 11:46 AM
No, but I just realized something. I switched motors. This is out of a 96 Park Ave. Supposed to be the same motor. Maybe a early 97 (made in 96) is different then a 96 3.8?
Chris.
P.S. It shows I have a picture for my signature, but it doesn't show up. C man, how did you get yours to show up?
New Balance 662
Trek 8000
Old 09-24-2009, 07:17 PM
Jrs3800 Jrs3800 is offline
Somewhere along the line the dip sticks changed position for the cross hatch area... Are you using the 96 Dip Stick?
When I swapped to a newer 3800 in my van I made sure to get the Dipstick with it so that I would know the proper level.. The Dip stick and Tube changed lengths somewhere along the line..
Generally you should be able to get away with running 5 quarts in a 3800.. General rule is 4.5 quarts... I have always run 5
Old 09-24-2009, 07:25 PM
No, same dip stick that came with motor.
New Balance 662
Trek 8000
Old 09-24-2009, 09:14 PM
HotZ28's Avatar
AF Moderator Elite
I think you may have found your answer! '96 Series II engine calls for 4.5 qts with filter; so therefore, the dipstick & tube were designed to show full level with that amount. If I add 4 1/2 qts with filter, it shows the level as full. As previously mentioned, if I add an additional 1/2 qt (which I occasionally do) it will show the same as yours.
It’s no big deal if you add 5-qts, it will not harm anything. It could be that GM finally decided that most people would not add oil until the dipstick is showing a quart low; so in theory, if you are driving @ highway speeds with 3 1/2 qts in the engine, you have 2-qts circulating and only 1-qt in the pan. Now if you are driving @ beyond normal highway speeds, or on curvy roads, 1-qt in the pan could present a problem, hence the additional recommended ½ qt! Logical thinking!
Old 09-24-2009, 09:22 PM
One thing tho. My 97 car manufacture date is 3/96. The new (used) motor I got was made in 96. What would be the difference in a 3.8 made in 96, and a 3.8 made in 96?
I read that the motors where "unchanged" from 96 to 97 (even tho my car was made, in march 96). The 96 Park Ave was made after my 97 Lesabre, with the motor being, "unchanged". What would of changed?
Chris.
New Balance 662
Trek 8000
