Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-22-2009, 03:16 PM
alpinefun alpinefun is offline
A/Trans drain plug gasket
I am going to flush the transmission fluid on my 99 T4R and I wonder if I can reuse the drain plug washer. Does anyone know the Toyota's P/N for this washer in case if I have to replace it? Thank you.
Old 09-22-2009, 06:29 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: A/Trans drain plug gasket
Yes, you can resuse the gasket. The only way you will have to buy a new one is if you loose it.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-22-2009, 07:56 PM
Thanks Brian. I wasn't sure if this is crush washer or a flat type one. It looks like the previous owner has never changed the T/fluid for 98K miles so I am going to to do it in my garage this weekend. I am not trying to safe a buck on this washer, I am just running out of time to buy the new one. I have red some posts on the other websites regarding this DIY job but if you guys have some extra advise / recommendation to share with, I am listening...
Old 11-08-2009, 07:09 AM
ycl1688 ycl1688 is offline
trying to change transmission fluid, the drain plug normally just like taking out the oil drain plug using 14mm socket, plug does not come out, even losing it, what is the problem ?
Old 11-08-2009, 03:05 PM
Brian R.'s Avatar
Resident Chemist
You are too weak. Get stronger....
Old 11-09-2009, 05:22 AM
how strong you want to be to get a plug out, it is same principle as taking out oil drain plug. It is turning somehow there is resistance.
Old 11-09-2009, 09:32 AM
Brian R.'s Avatar
Resident Chemist
If it is turning, it will come out unless the threads are stripped. If the threads are stripped, you will have to pull the pan and figure out what needs to be done to fix it.
Old 11-10-2009, 10:22 AM
Pull the pan and seal the drain plug inside and outside, not much choice. Should be good for another 60k miles.
Old 11-10-2009, 12:36 PM
Brian R.'s Avatar
Resident Chemist
Replacing the pan is an option. Salvage yards should have one.
Old 11-10-2009, 12:56 PM
Brian,
thanks. Will be looking into that.
Old 11-24-2009, 03:28 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Dont even bother "sealing" the faulty drain plug and components. you will be faced with the SAME problem again when you need to drain the fluid.
As Brian said, do it right, pick one up cheap at the auto recyclers.
"I cut the header twice, and it's STILL too short!"
