Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 09-22-2009, 08:57 AM
gln7 gln7 is offline
Rattling noise in AC compressor
There's a clattering/rattling noise coming from my AC compressor on my '95 Lumina APV, 3.8 engine. The noise starts as soon as the van is started, even with the AC off. When I turn the AC on, the clattering speeds up. Would this be the clutch gone bad? If so, can the clutch be replaced without getting a whole new compressor? Thanks.
Old 09-22-2009, 09:10 AM
SUPERDAVE22 SUPERDAVE22 is offline
Re: Rattling noise in AC compressor
Could be that or the compressor bearings going bad
Old 09-22-2009, 10:49 AM
Thanks. Is it safe to drive it like this, or could it damage my drivebelt?
Old 09-26-2009, 07:20 AM
LMP's Avatar
LMP LMP is offline
First, I'd bypass the a/c with a shorter belt. THis will give time to investigate.
With A/C the serpentine belt is 102.5", PN 1025K6. With out A/C the belt is 72.5", 30" shorter, PN 725K6. (based on '93 3800..should be similar)
www.avigex.ca/xport/serpentinebelt.jpg
MOst of the time, the free wheeling bearing is the culprit, but then the noise stops when the a/c is ON....and check if it really comes ON when you turn the A/C ON, as a loss of refrigerant pressure will prevent operation anmd the noise would continue...
From the wheel well, you can remove the inner plastic cover and then rotate pulley by hand . Free wheeling bearing can be changed from there.
Noise cannot be the same running and not running: when a/c is not engaged, only free wheeling pulley rotates, involving free wheeling bearing and possibly damaged friction clutch . Inner bearing and compressor itself do not rotate than. ONce a/c clutch is actually engaged, then inner bearing and compressor will rotate, but then free wheeling bearing and friction clutch are noiseless. Possibly, the clutch material can be damaged and protruding, making noise against the free wheeling pulley when off, and touching other components when rotating.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 09-26-2009, 01:34 PM
Thanks for the info, LMP. Will try the short belt and go from there.
Old 09-26-2009, 02:00 PM
LMP's Avatar
LMP LMP is offline
...and notice that the a/c is turned ON without your knowing whenever MAX COOL(recirculate), DEF or HEAT/DEF is chosen, except when temperatures are below freezing.
