Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 09-22-2009, 08:43 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
nitrous spray bar, meth
For anyone who knows a lot about nitrous and meth kits, this should be easy to answer.
I wanted to know what the difference is in getting a nitrous spray bar kit, or a meth kit.
I know what both of them do, but does anyone know which is a better choice? I mean they both act to cool the intake charge correct? but the spray bar just cools the intercooler right? So, could you have both? Or is one sufficient for what its doing?
IF I were to say go with the spray bar kit, bc I do want this turbo nitrous kit which sprays until you hit peak boost, would I be able to use one bottle for two things? on the motor, and on the spray bar?
Or, just a combo of nitrous for the engine, and a seperate meth kit...
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 09-22-2009, 09:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: nitrous spray bar, meth
I heard IC coolers are a waste. Meth seems to be a good choice.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-22-2009, 10:51 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I wouldn't say they are a waste. Turbo cars are always battleing cooling the intake charge more. An intercooler sprayer will cool iats down. Meth will also do the same but at the same time increase your octane rating slightly. So you could use both if you wanted to. The only thing I have against the intercooler sprayer is nitrous refills are so expensive. Its normally 3-4$ a pound which is 40$ for 1 tank refill. I pay less than 2$ a gallon for meth which lasts for a month or two.
I would say depending on how efficient your setup is you may not even need extra cooling. Until you actually lot your air temps you won't know. Also you can use 1 bottle to inject nitrous and run the sprayer
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-22-2009, 11:26 AM
ok that what i was wondeirng, i may just scrap the spray bar idea...if meth is sufficiant. this is of coarse down the road, if theres room for it after its all tuned up...
thanks!
Old 09-22-2009, 11:20 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Did you make an air dam?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 09-23-2009, 07:16 AM
what do you mean? im not sure what an air damn is...explain please
Old 09-23-2009, 08:34 AM
I wont explain, but the link will very easily
http://www.automotiveforums.com/vbul...d.php?t=762473
From what the tests have shown from others, intake temp is only a few degrees over ambient temp.
95 Eclipse GS-T
Currently:
Soon lol
david-b's Avatar
Dave is THAT guy
An air damn would usually be a piece of metal underneath the car, mounted under radiator to "scoop" up some air and flow between the IC and the radiator or to scoop up air into the engine bay. The reduces engine temps slightly, especially if you still have your A/C core. There's a big write up about it on Tuners.
Not sure however, what that has to do with anything that your talking about
75 Monte Carlo
Old 09-23-2009, 08:36 AM
david-b's Avatar
Dave is THAT guy
Wow, same time response lol. The above link is more of an air box, although with the scoop in it I guess it can be classified in the same way.
75 Monte Carlo
Old 09-23-2009, 08:51 AM
Holset powered 420a
It does help lower air temps, however he has a 420a not a 4g63. I would suggest moving your filter out of the engine bay if at all possible. I did notice a little gain in HP after that.
SGanc4life - Those recorded temps are taken at the maf. Those temps may not even be close to what is actually going into the motor. But the intake temps going into the turbo will be lower which is a good thing
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-23-2009, 09:02 AM
Ah, I remember glancing over that article months ago lol. And funny on the same time posts.
95 Eclipse GS-T
Currently:
Soon lol
Old 09-23-2009, 05:59 PM
Ok I was hoping this would come up. I have a question about that...
Weapon R makes this ram air flex tube that attaches to the end of your performance filter, and you can position it so that air is hitting it...anyways, I was wondering, if any of you had done this or something similar, and will ramming air like that into the filter really do much more than not? If this is worth while, and I were to get it and place it behind the smaller hole on the side of the front bumper, is there some way to prevent moister or rain from getting pushed through and into the turbo?
Old 09-23-2009, 11:42 PM
Having cooler air flowing into your engine is always a better thing. As for the moisture prevention I really have no clue about that except for maybe taking it off if you have to drive in heavy rain.
Personally, I would do a DIY with the "air dam" I was speaking of or maybe something similar to what you're talking about. The water thing would be my reason for option 1.
95 Eclipse GS-T
Currently:
Soon lol
Old 09-24-2009, 12:11 AM
Holset powered 420a
Just put the filter in the bumper and it will be fine. No reason to run that rediculous tube to the filter. I highly doubt you will see anygains. I did however notice a good gain when moving the filter off the turbo to inside the fender. Faster spool and produced another .5-1psi or so.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-24-2009, 08:13 AM
so there needs to be a section of intake tube? could i see some pictures of what yours ended up looking like?
