Old 09-21-2009, 11:30 PM
nniemi's Avatar
nniemi nniemi is offline
Q-Model Dino 246SP High Tail
Alex did a great review on this kit, so i don't need to do that anymore. I found my kit on Ebay from a Hong Kong seller the day after Alex did his review. Received it yesterday, and since i don't collect unbuilt kits had to start it straight away. I spent the first evening with one of the rear wheels. What a pain in the neck, but result is IMO worth it.
This is the first layer of spokes, i will have to make other three a bit more symmetric. At this point i was thinking why they don't do wheels like this anymore.
First two spokes of second layer answered my question, it is quite hard to get those thin spokes get across each other and then fit the slot in the hub.
Here is the second layer finished:
Just when i thought that the second layer was tough work, the third layer is even tougher. Spokes cross each other and the second layer of spokes...
Here is the whole wheel tire package. Wheel is painted with Testors Aluminium Metalizer. The real advantage of using wire spokes glued one by one is that they really do cross each other in a lot more realistic way than the PE wheels used in modern multimedia kits.
-Niko
Old 09-21-2009, 11:37 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Re: Q-Model Dino 246SP High Tail
Dare I ask how much time was spent on just the wheel?
Old 09-22-2009, 05:40 AM
jano11 jano11 is offline
Wow!
That wheel looks good.
Only three more to go!
Old 09-22-2009, 08:07 AM
klutz_100's Avatar
Originally Posted by nniemi
Niko, it's not like you to pass off 1/1 photos as your own work
superb!
Old 09-22-2009, 08:19 AM
360spider's Avatar
Very cool! Will follow this thread closely!
ItalianHorses.net
Old 09-22-2009, 09:34 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Fantastic! Looks fascinating and terrifying, but the results are spectacular.
How are the wires attached to the centre hub? Are the ends glued to the hub, or do they wrap around the hub to end on the rim?
How long did it take? Are you looking forward to doing three more, or fearing them?
PHOTOBUCKET SUCKS
Old 09-22-2009, 09:54 AM
360spider's Avatar
Andy, I guess you don't want me to post the lower half of the page anymore? I see you found the thread that I wanted to send you a link to! :-)
ItalianHorses.net
Old 09-22-2009, 10:17 AM
nniemi's Avatar
Six comments/wheel not bad
It took about three hours from opening the box. Actually i just wanted to see how this mess of brass wire works and as you see it works just fine. I used regular superglue applied with sharpened toothpick to attach spokes to the hub, they don't wrap around the hub. After all spokes were glued to the hub i just coated outside of the rim with superglue, let dry and used my dremel to cut spokes even with the rim.
Somewhere in between of those options, i didn't actually like doing the first one, but i believe that i did learn something and next three will be a bit easier to do.
-Niko
Old 12-02-2009, 08:26 AM
nniemi's Avatar
Finally found some motivation to do continue this kit. Used around 12 hours to glue 180 spokes... After that the chassis was a pure joy, just painted seats, chassis plate, glued couple of PE parts and it's done:
Body is also painted and decaled.
-Niko
Old 12-02-2009, 02:20 PM
F1Tommy F1Tommy is offline
Looks pretty good. Those brass wire wheels look alot better than I thought they would.
Tom Tanner/Scale Designs/Ferrari Expo-Strictly 43rd Revival model/photo contest-Chicago April 24th 2010
Old 12-03-2009, 10:12 AM
godfather23's Avatar
godfather23 godfather23 is offline
Looking really great. The work on the wheels is mindblowing. But itīs worth every minute spent on them. Way to go!
The calming part of the wheel work is that you know that afterwards it can only get easier.
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
