2000 Windstar P102 code question
It was very sudden that the car started stalling out, slight pedal pressure will not keep it running and often when I depress the pedal it starts stalling and sounds like it's sucking air.
After a stall it will start immediately and idle for a few minutes like nohing ever happened. Then it will stall as though the fuel supply was shut off. I have a P102 code for MAF sensor according to my tester. Are these normal symptoms for a MAF failure? I found part availability at NAPA for $139 and I am willing to drop my $ there before limping into the dealer. Advice anyone? Edit: I tried cleaning with the recommended cleaner with NO effect whatsoever. Last edited by da180; 09-21-2009 at 09:28 PM. Reason: Additional |
Re: 2000 Windstar P102 code question
unplug it.
car will still run. should sound better. sounds like a maf to me, but dont just go off me, id try pulling the harness and see what happens. |
RESOLVED!
Lacking any other apparent possibilities/DTC's I replaced the sensor and all is well. It is odd that the defective sensor will disable the car, yet unplugging it allows it to run. |
