Old 09-21-2009, 09:36 PM
SkylineFan's Avatar
SkylineFan SkylineFan is offline
Kurt Johnson's AC Delco Cavalier Pro Stock
This is a project Clay wanted from me when complete. I dont know why when he builds his own outstanding Pro Stocks. He bought me the body, decals, tires, etc... I supply the labor and I guess get a big kiss when I give it to him..... ;D ;D ;D
This is KJ's Pro Stock Ac delco Cavalier Extreme build. I started with the chassis like I always do on these builds. Alot of cutting, scratchbuilt bars grace this thing to make it a modern pro stock. I used the Summit Racing Firebird pro stock kit as a starting point. The front lower control arms were made from aluminum tubing and PE heim joints. Here are the stage pics from Metallic Grey basecoat to paint. It looks like my WJ car really! Adding the Carbon fiber to the tunnel and wheel wells is a daunting task!
Once the chassis was done and fitted to the body properly, I cut it all apart, finessed it and primed it. Here are a few primer mock ups... The rear wheels have anodized beadlock rings from a slot car supplier. The front wheels are also from the same supplier that Clay picked up for the build. I believe they are called Pro Track slot cars.
And.... Jumping ahead!!! Its in paint! House of Kolor Kobalt Kandy Basecoat is the ultimate blue. I painted the white and blue. Added one coat of clear, Slixx decals, and more clear.... I have not polished yet but need to do a few areas....
Old 09-21-2009, 09:37 PM
SkylineFan's Avatar
Re: Kurt Johnson's AC Delco Cavalier Pro Stock
the Front end is on its way, scratch built lower control arms, Steering rack ends, and steering shaft.
And here is my new engine plate that I made with my Lathe and mill..... Metal snips, a pin vise, a mallet, and 800 grit paper!!! ;D ;D It was a bargain!!! Aint it cool how it looks like a bowtie? Not intentional!!
ANd all the final polishing to perfection was achieved on the paint.....
SkylineFan's Avatar
The block and trans are from the kit, The valve covers are Competition resin pieces which really beef up the look.... The oil pan, Pulleys, Oil tank and Breather are all Machine works indy.... Distributor is from pro tech.
All oil lines, and fittings are detailmaster. The oil filter and sump pump is scratchbuilt along with my engine plate Enjoy!!
Old 09-21-2009, 09:39 PM
SkylineFan's Avatar
Got the rear suspension built and installed today. Its all scratchbuilt from Aluminum and plastic .060 tubing. The heim joints were made by mashing the ends of #3 DM hardline and sliding a Pro tech .035 hexnut up against them . The diff and ladder bars were painted with alclad dark aluminum. Then black was misted to simulate the heat joints. Brakes are DM PE Pieces and the shocks are from R&D unique.
Rear slicks are complete and detailed.. Decided to "shoepolish" these up! ;D Just need to add a black wash to tone down the rims later...
DaveT
SkylineFan's Avatar
I scratchbuilt a C&R Radiator today....Made from square tubing and sheet styrene with a PE radiator core from detailmaster.
And a test fit in the car......
Old 09-21-2009, 09:41 PM
SkylineFan's Avatar
The engine bay is ready for a permanant installation of the engine.... I scratchbuilt a Master cylinder and plumbed it with hardline. The fuel pump used up front on KJ's car is made by magnaflow. I downloaded a few pics off the net and replicated it as close as possible using Aluminum tubing, solid aluminum tubing and a #3 combo fitting. All I have to do now is scratchbuild a fuel cell and plumb it up.
The seat is also complete and installed. Completely carbon fibered, cleared and belts and hardware installed.
And another hurdle covered... The Shift linkage. I made this thing based off of pics of a G-Force Trans that KJ runs in his cars called the GF-2000. A clutchless 5 spd that pro stocks run. All of it is pure scratchbuilding with sheet styrene. It will be complete once I add the Heim joint links once the engine is in place.
Old 09-21-2009, 09:42 PM
SkylineFan's Avatar
MAJOR hurdles this weekendon the engine bay... I will be taking a break for a week to knock out a few other projects, but I really wanted to get the engine detailing for the most part done. It needs electrical wiring and a coolant overflow tank but thats about it. Man it gets real busy looking once everything is in place. Alot of profanity was slinging in my brain and some out loud but I got it done...... Headers were done with various alclads by the way. The Carbs are Barry Grant Demon units from Pro tech.
I also got the heim linkages all hooked up to the clutchless 5 speed shifter I scratch built.
And I could not resist... I had to get that Massive rear slab wing mounted... it just makes the car look sinister....
Man its starting to come alive!!!!!
More soon.... but for now its got to sit...
DaveT
Old 09-22-2009, 11:48 AM
kans0002's Avatar
kans0002 kans0002 is offline
not my style but an absolutely stunning build. super clean and really well detailed. I will be following this one closely!
Old 09-22-2009, 01:22 PM
sam01contact's Avatar
sam01contact sam01contact is offline
WOW! That's not model building...that's ENGINEERING!!! You guys are in a different league!
Old 09-22-2009, 04:43 PM
jaykay640 jaykay640 is offline
Awesome work as always! Great scratchbuilding, superb finish. Always fun to see your inspirational builds :-)
Old 09-22-2009, 04:52 PM
beaver63's Avatar
beaver63 beaver63 is offline
How else to comment on.
Old 09-22-2009, 05:37 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Awesome work! I like Cavaliers to being with, and now you're building one! I'm watching for sure.
Old 09-22-2009, 06:46 PM
AAlmeida's Avatar
AAlmeida AAlmeida is offline
Can you detail how did you get that color for the exhaust, you said Alclad but which colors and steps? Professional build by the way.
Almeida... I'm back!
Old 09-23-2009, 01:59 AM
sportracer02's Avatar
Hi Dave, another masterpiece seems to be finished soon - fantastic job !!!!!
Micha
Old 09-24-2009, 08:14 AM
The Sheene Machine's Avatar
The Sheene Machine The Sheene Machine is offline
After all these years, I'm still blown away with these builds. You guys are not in a different league....you're from a different planet!
Beautiful, clinically clean work.
Paul
On the bench;
2003 LV Rossi Honda RC211V
