Old 09-21-2009, 07:24 PM
KX5OO KX5OO is offline
97 Cherokee Serpentine Belt Tension?
97 Cherokee 4.0L. How do I determine the correct belt tension? I bought a Krikit II belt tension tool. The instructions are a little vague. I'm not sure how to use the tool? Anyone have any experience with the Krikit II?
Old 09-21-2009, 11:30 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 97 Cherokee Serpentine Belt Tension?
Isn't it an automatic tensioner on the 97? I guess maybe not.
In general you want to have the longest travel between pulleys move no more than 3/4" when you push on it fairly hard. The tool probably applies a calibrated amount of pressure and measures the distance the belt is deflected.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-22-2009, 08:23 AM
2000izusu 2000izusu is offline
i tightened mine down so the belt would not squeal on start, but if you go to tight their goes your water pump bearing!
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 09-24-2009, 04:58 PM
No, it is not an automatic tensioner. Its manual. The pulley is attached to a long bolt. I've already had trouble with a shop over-tightening the the previous belt. They ended up replacing the water pump. The over tight belt fried the bearing in about 2 days.
Old 10-06-2009, 06:25 PM
LowBudgetBuilt's Avatar
LowBudgetBuilt LowBudgetBuilt is offline
Originally Posted by fredjacksonsan: In general you want to have the longest travel between pulleys move no more than 3/4"
that how ive always done mine no more than 3/4" of movement between the 2 points furthest apart.
1989 K5 Blazer
-6" susp. lift
-35x12.5R15's
