Old 09-21-2009, 11:36 AM
colt72108 colt72108 is offline
Exclamation 2001 RPM Problem (IAC)
i have a 2001 accord lx and im having a problem with the Air Control Idle Valve. (i think)
the check engine light comes on and the rpms are fluctuating between 500 and 2000 in park/nuetral. i read the codes and got "IAC NOT RESPONDING/ LEAK IN HOSES"
i checked them and there was no leak from what i could tell. would the only way to fix this problem is to replace the IAC?
cuz i dont wanna drop $200 if i dont want to... :/
Old 09-21-2009, 05:45 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 2001 RPM Problem (IAC)
Just for laughs check your coolant level in the radiator.
Low coolant will surge across sensors and through hoses for temp controlled items and cause rolling idle speed like that sometimes. I haven't looked how that one is set up, don't know if it can cause it on yours. Often did on older ones...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-22-2009, 12:34 PM
1st, i love the quote u got. lol
2nd i fixed it. the iac was fully sealed againts the intake. i took it off, cleaned the corrosion off, resealed it and everythings working like a beaut!
thanks though
