Old 09-20-2009, 11:51 PM
mistermatrix24 mistermatrix24 is offline
Rookie System Installer
okay so i bought a nice 1700watt lightning audio system and am in the process of installing it. it all seems very straight forward and installation isnt exactly what my question is regarding. i have a few small ones. so
Number 1: my system has two amps,a B4.250.2 and a B4.320.4 now the 320 has 4 places to connect speaker wires fronts LR and rears LR and the 250 has 1 Left and Right. my car has 6 speakers. (4) 6.5" and (2) 4". should i wire the 6.5" speakers to the 320 and the 4" speakers to the 250. that makes sense but im not sure if thats the way it should be done.
Number 2: the 6.5" speakers in my front doors are still stock and i dont have replacements for them at the moment. im looking at some online and found a good deal on a set of 3-way speakers. but the ones im installing now in the back are 2-way. will this cause a problem or is it fine to install different speakers in the same system?
Thanks,
Thomas
Old 09-21-2009, 05:44 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Rookie System Installer
everything sounds like it will be ok, but it may be difficult to tune with all those speakers
Old 09-21-2009, 09:59 AM
yeah. but using 3-way speakers with the 2-way's wont cause problems tho right?
Old 09-21-2009, 11:29 AM
Big_red16424 Big_red16424 is offline
in reference to what?
If you have a 4 channel amplifier and a 2 channel amp.
Hook 4 speakers up to one,
hook 2 speakers up to another.
Start tuning them by using low volume on the amps with 50% on the head unit to start with.
Then turn up the amps independently until you reach equilibrium.
adjust your bass boost accordingly.
I still do not understand your question in reference to
*using two way speakers with 3 way speakers*
3 way speakers are, bass, mids, highs,
2 way speakers are, either, mids, highs or bass, highs
Old 09-21-2009, 11:52 AM
thank you that helps a lot. and what i mean is that right now i have (4) 2-way Speakers hooked up to the 4 channel amp. and im asking if i replace (2) of those speakers with a pair of 3-way speakers will there be a problem.
Old 09-21-2009, 05:43 PM
Audio Guy
a coaxial just has one tweeter, a triax (3-way) has two. It won't effect the sound much as far as balance, maybe the 3-way will be a little brighter
Old 09-22-2009, 11:32 AM
badluck4us badluck4us is offline
Do you have a SUV or something? Thats a lot of speakers lol. If you tune everything the right way, you really shouldnt be able to tell. Its not a problem at all. Good Luck!
Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) Sprint PPC6850SP
Old 10-12-2009, 12:01 PM
so long as the Ohm's are the same it wont cause ANY problems whatsoever.
the 3way systems are basically 2 way speakers with a Tweeter mounted on top.
As long as the OHM load is identical to the 2way speakers you'll be just cherry
