Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 09-20-2009, 08:45 PM
kenthurgood kenthurgood is offline
Cannot start my Rendezvous
Hello everyone,
My 2004 Rendezvous' check [COLOR=blue !important][COLOR=blue !important]engine [COLOR=blue !important]light[/color][/color][/color] came on and I thought that if turned the ignition key a few times to the on position without starting, it may clear the fault, or give me an error code (Big Mistake) A chiming noise came from the dash and then everything went dead. I disconnected the battery hoping this would fix the problem. The lights worked again and so I put the key in the ignition and all the proper lights on the [COLOR=blue !important][COLOR=blue !important]instrument [COLOR=blue !important]panel[/color][/color][/color]
came on. Turned the key to start and everything went dead again. What have I done ??? Desperatley need advice.
Old 09-20-2009, 11:39 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Cannot start my Rendezvous
Are you sure you have the battery cable ends tight to the battery?
Old 09-23-2009, 04:18 AM
Hi again,
Thanks everyone who replied.
Yep ... turned out the cause of all my grief was the battery cable having not been tight enough.
It was on good, but l could tighten it more using a small wrench.
Thanks again.
