Old 09-20-2009, 08:35 PM
adam0421 adam0421 is offline
Changing fuel pump. connection ???
I have the tank out and everything disconnected other than 2 connections. They are the 2 connections that go to the box located directly behind the fuel filter. How do I unclip these connections?
Old 09-20-2009, 09:24 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Changing fuel pump. connection ???
You squeeze the flat parts inward which pushes the locking tabs clear of the barb. You can see the tabs on the blue fitting in the lower picture... if squeezing them alone doesn't work, you may need to get a small screw driver in there and help it out a bit.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
