Old 09-20-2009, 01:08 PM
INF3RN0666 INF3RN0666 is offline
Crackle in the front suspension
Hey
I was driving a 2003 buick century. When I come to a stop or accelerate from a stop, there's a crackle from the front suspension as the front end dips or rises. Somebody said it was the mounts, but I'm not entirely convinced. Any idea what it could be?
Old 09-20-2009, 10:42 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Crackle in the front suspension
It's very difficult to diagnose noises over the Internet. Your 'crackle' may be my 'creak.' Can you duplicate the sound by jouncing the front of the car with the car in park? Does it sound like dry rubber on steel? Or does it sound more like air rushing through a small hole? Is it brief, like only as the car's front end travels one direction, or the entire time you accelerate or brake? Certainly when it comes to sounds, the more information you can provide the better. Also, since this noise likely is specific to the type of car, have you tried searching the Buick Century forum?
-Rod
Old 09-21-2009, 05:02 PM
It sounds like compressing dry rubber. The noise occurs at the end of the braking or just at the begining of the acceleration.
Old 09-21-2009, 08:56 PM
shorod's Avatar
SHO No Mo
I'd suspect struts or anti-sway bar bushings. But, I would first suggest you try that search of the Buick Century forum to see if this is a common issue others have fixed.
-Rod
Old 09-25-2009, 03:17 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
It could be the rubber strut boots that cover the struts and keep dirt and water out. They can get old, cracked, and split open. I've even seen then wedged up in the upper strut mount after coming loose.
Other possibilities are sway bar end links, control arm bushings, and ball joints. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
