Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-20-2009, 11:45 AM
homer0101 homer0101 is offline
2001 ford coupe cyl. #1 mis-firing
cyl. #1 is miss-firing I changed plugs and wires still mis-firing only cyl.#1 please help.
Old 09-27-2009, 11:24 AM
motu 56 motu 56 is offline
Re: 2001 ford coupe cyl. #1 mis-firing
check the sevice engine light post above
Old 10-02-2009, 11:06 AM
Davescort97 Davescort97 is offline
Escort guy
A misfire can be caused by other things than the ignition. Most likely you have a vacuum leak close to the #1 cylinder. Check all your vacuum hoses especially the ones that run from the PCV valve to the intake.
