Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-20-2009, 11:36 AM
homer0101 homer0101 is offline
missfiring
I have a miss-fire on cyl.#1 I changed plugs and wires all ready can the coil miss mire for only 1 cyl.
Old 09-21-2009, 06:24 AM
Davescort97 Davescort97 is offline
Escort guy
Re: missfiring
Welcome to AF!
When you take the ignition wire off #1 plug while the engine is running is there any change in RPM? Or... are you picking up a Diagnostic Trouble Code that #1 is misfiring?
It could be that there is a vacuum leak close to that cylinder on the intake or it could be that #1 cylinder doesn't have enough compression to fire. Perform a compression check.
Remote...,but is the plug gapped properly on that plug? Is the connector down securely on that plug?
