Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-20-2009, 10:57 AM
2000BlkBonneville 2000BlkBonneville is offline
Exclamation 3 windows 3 locks not working
I have a 2000 Bonneville SSEI love the car but i have not pass window and no rear windows i know that the back windows need new window regulators. but the drivers lock and window work fine i have pulled passanger seat and checked all wiring and found everything to be fine what else can i do to
Old 11-07-2009, 01:52 PM
bozoman66 bozoman66 is offline
Re: 3 windows 3 locks not working
You have a bad ground at the junction block under the carpet along the drivers side rocker. Remove sill plate and pull back carpet. You'll see the junction block. Clean as necessary. I had the same problem. Mine also killed the fuel pump.
Old 11-07-2009, 02:29 PM
Mickey#1 Mickey#1 is offline
Hi Bozoman,
What year is your car? The corroded ground bus is a fairly common problem on the 1999 & older cars but I'm not sure if we've seen it on any of the 2000 & newer cars.
