Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 09-20-2009, 10:28 AM
alexarav's Avatar
alexarav alexarav is offline
01 Sonata Engine Stopped while in Motion
So here's the deal with my automatic 01 Sonata GL 2.4 L. During the day yesterday i had a moment where the car was turned on, was idling for two minutes and then suddenly it turned off. I wasnt paying attention and thought i never actually turned it on; thought no more of it.
Later that night i was driving on the road at around 60 km/h when the engine suddenly went dead. I pulled over. No fluid leaks, all lights are on. Attempted to crank the car; car cranks fine (indefinately if i keep holding the key there) but engine never turned on. I tried this several times...at one point i attempted it and the engine even turned on for all of 2 seconds and died again. Lots of fuel, temperature guage okay.
Could this be a cam sensor? Any theories would be appreciated....i'd like to get an idea of how major a problem this might be.
thanks!
Old 03-07-2010, 02:01 AM
mikasa mikasa is offline
Re: 01 Sonata Engine Stopped while in Motion
Check compression.If spins fast more likely timing belt.
Old 04-03-2010, 06:32 PM
dbacon dbacon is offline
If you lost your timig belt, you would have trashed your engine. It is an interference motor, the pistons will hit the valves, nasty things happen.
I don't know on this car but on a couple other cars I have seen the cam sensor go bad, sounds likely. They are just a reed switch and a magnet, when a tooth comes by it closes the switch. They are pretty unreliable in any car. I would change it just for openers.
2000 Sonata, 2.4L 4 Cyl, Auto, Cruise, AC, Pwr windows, Remote mirrors.
Mods:
-Trunk light, internal switch & safety trunk release.
-Removed panel behind rear arm rest to trunk.
-3rd gear i.p. light cycles in 7 colors.
-Fuel low light, now is a blinking red LED.
-"Lights left ON" beeper (Why didn't it have this?).
-Separated the Batt warning from the low brake fluid warning.
-AG 1201 Remote start, door unlock & trunk release.
-Added "Valet" illuminated symbol to i.p.
