Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-19-2009, 08:07 PM
maboudre maboudre is offline
91 4runner A/T oil temp light, and temp. gauge
I have a 91 4runner v6 4wd, If I drive my car over 50 miles, my A/T oil temp light comes on and my temp gauge goes up. Its not exactly at 50 miles but around there. Does anyone have any ideas why? It is fine after it is turned off for a couple hours.
Old 09-19-2009, 09:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 91 4runner A/T oil temp light, and temp. gauge
How is your gas mileage? If it is pretty bad, maybe you have a drag on your vehicle which is causing the AT to work harder than it ought to. Do you drive on really hilly terain? Is your radiator filled? Check the radiator at the radiator cap when the engine is cold. It should be topped.
When is the last time you checked your ATF level? Maybe you are low on fluid. Have you changed it in the last 100k miles?
If everything seems to be good, pull one of the hoses to the tranny cooler, hook another hose to the radiator nipple with both hoses in a receiver and then idle your engine. See if there is a reasonable flow of fluid through the radiator. You should get around a quart in 5 seconds if my memory serves.
See if your radiator is plugged internally (watch the flow with the cap off cold) or has a lot of debris blocking air flow through it. Does your radiator fan work correctly?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-24-2009, 09:39 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Check that you don't have a pinhole leak in your radiator by using a pressure test kit. If the cooling system can't maintain the ~15 psi pressure (I'm guessing, don't know your truck's actual spec), then the temp will eventually creep up due to the boiling off of water and coolant. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-16-2009, 01:48 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
If you have been in the mud check the AT oil cooler mounted on the frame on the passenger side near the front of the tranny. Just a thought, post us back when you find out. (this shouldn't affect the engine temp though...hmmmm)
"I cut the header twice, and it's STILL too short!"
