Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-19-2009, 04:12 PM
Mike0313 Mike0313 is offline
1993 GMC hard starting
I am having a similar problem that another member had with his '93 Suburban. My truck is a 1993 GMC Seirra pick up, 5.7 litre gas engine.
The engine has 345,000 kilometers (215,000 miles) It will usually start when cold and never stalls. After driving for a while then stopping the truck, say to go into a store for 15 minutes, it won't restart. If I crank it too much I'll of course kill the battery. I let it sit for about 30 minutes then it will start like nothing was ever wrong. I have replaced the cap, rotor, wires, ignition coil. Could this be the ignition module overheating?
Is the ignition module IN the distributor on these trucks? My poor truck has been parked for months. If I take it to the dealer they want $120.00 just to tell me whats wrong with it. Hope somebody can help.
Old 11-09-2009, 03:42 PM
zeakieb1 zeakieb1 is offline
Re: 1993 GMC hard starting
check your fuel pump i had one that did the same thing the wiring harness inside the fuel tank was bad
Old 11-10-2009, 12:18 AM
2000CAYukon 2000CAYukon is offline
When it won't start, you need to determine if it is getting fuel and spark. The Engine Coolant Temp sensor can also cause a hard start issue. If it is reporting a cold engine temp, the ECM will deliver too much fuel and it won't start and become flooded.
Fuel pressure specs are 9 to 13 PSI and look for a good blue spark.
//2000CAYukon
Old 12-17-2009, 05:43 AM
sleddinskeeter sleddinskeeter is offline
Ignition module under the cap is heating up after intial start. you can remove this and have it tested at most parts stores for nothing Pretty common on one with that many miles.
