Old 09-19-2009, 04:10 PM
peanut77 peanut77 is offline
1996 t&c fuel sensor problems
just got finished replacing fuel pump with a new aftermarket one and now everything works but when i put the van in reverse the gauge drops to empty but if i put it in any other postion everything works fine. when i did the key on/off trick i got #42. while i have power to the pump i have 3.5 volts on the blue wire in every gear except reverse when i put it reverse the voltage shoots up to 11 volts and the gauge drops to empty. Any ideas would be greatly appreciated
Old 09-20-2009, 12:13 PM
Re: 1996 t&c fuel sensor problems
it turned out to be in the wiring of the new fuel pump
