Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 09-18-2009, 07:59 PM
braintech928 braintech928 is offline
2006 electricial problem
2006 sebring touring v6 fwd
originial problem
starter went out....it would blow number 8 fuse went you try to start it
disconnected wire from starter motor stop blowing fuses...
replaced starter
now...radio...interior lights...auto door locks dont work...
door locks will work with the key in the on postition
hooked up code reader no power to it reads nothing
checked all fuses and relays all good
please help losing hair.....
Old 09-18-2009, 11:54 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 2006 electricial problem
Do you have power at fuse #5 (10 amp)? That one supplies power to the lock switches, radio, and interior lights.
Old 09-19-2009, 07:30 AM
yes there is power there
Old 09-19-2009, 12:57 PM
Airjer_'s Avatar
The next step would be to check power on all the pink wires. There is one that goes to the ALDL which may be the easiest to start with. Then focus on the lock switches, interior lights and the radio.
Old 09-19-2009, 03:21 PM
aldl...?
did learn if i turnthe head lights on the power locks will work
is there some kind of module connected to the interior fuse box?
Old 09-19-2009, 10:23 PM
Airjer_'s Avatar
ALDL (Assembly Line Data Link) - or the ODBII connector you use to check for codes.
