Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-18-2009, 03:07 PM
vinnievv vinnievv is offline
Unhappy Courtesy/Clk fuse keeps blowing
I have a 1988 Caprice. I was messing around with the radio a while back and now the crtsy/clk fuse keeps blowing. Sometimes it will be o.k. for a couple of days and than it will blow. Not sure if there is a problem with the horn. After the fuse blows anytime i try to put a new fuse in it blows as soon as i put it in. I appreciate any help anyone can give me
Thank you,
Vinnie
Old 09-18-2009, 03:45 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Re: Courtesy/Clk fuse keeps blowing
Short to ground or power,pull radio and check for a pinched or bare wire.
Old 09-18-2009, 03:52 PM
Thanks for your help.
Old 09-18-2009, 06:55 PM
j cAT j cAT is offline
Thank you,
Vinnie
not sure on your vehicle yr...on my 96 it was the driver door wiring that was the short...any wires that have no tape or loom covering best cover with this material...these shorts make little evidence..need good light and eye sight..any sharp metal near the wiring is suspect also.
Old 09-19-2009, 04:58 PM
caffeineaholic's Avatar
caffeineaholic caffeineaholic is offline
Do you still have the stock radio? It may be possible that the radio is causing this problem especially if you were messing around with it. On my '85 caprice the radio circuit runs off of the courtesy/clock circuit. In other words taking out the CTSY/CLK fuse will also shut off my radio.
Just today I realized that my new radio takes 10 amps and the stock radio fuse is 10 amps... Today I put in a 15 amp fuse and everything is working better and no blown fuses so far. However note that if you have a new radio that needs more than 10 amps you may also need to decrease the wire gauge a bit to accompany that (bigger wire).
Your accessory outlet/cig lighter may also run off of the CTSY/CLK fuse fyi.
Good luck.
1985 Chevy Caprice small-block V8 305ci (5.0L) - 4-Barrel Q-Jet (E4ME) - 700R4 - 115k+ mi. - resonator and A/C components deleted.
Driven in severe weather most of the year (Arizona 100+ degrees during summer heat or in wet weather especially in harsh monsoons). About 30/70 highway/city driving.
Old 09-21-2009, 03:07 PM
Smile Re: Courtesy/Clk fuse keeps blowing
Thank you all for your help and replies. I found the problem. I took the radio out and the problem is in one of the harnesses that attach to the back of the radio. Not sure if it is somewhere in the harness (as i suspect) or where the harness connects to the fuse box. Anyway, after i took out the mounting screws and pulled the radio out a few inches I was able to put in a fuse without it blowing. I wiggled the different harnesses and found the one that was blowing the fuse. As the radio wasn't working properly anyway, I just disconnected the harness that was causing the problem and than reinstalled the radio without connecting the bad harness. So far, so good.
