Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-18-2009, 02:13 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Spun bearing
Can someone describe to me the symptoms of a spun bearing?
I dont know much about it...and im trying to diagnose what might be the problem with my car.
Can your engine run each day with this condition?
because even those my engine rattles like crazy, it DOES still run each day just the same and still does fine...
theres no doubt some compression issues bc i can feel the power being robbed under boost compared to what it used to be like...
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 09-18-2009, 03:40 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Spun bearing
Do a compression test if you concerned about it. What do you mean rattling? Could it just be a fuel or spark issue?
Old 09-18-2009, 08:55 PM
Re: Spun bearing
no no the enigne is like, clanking around at different rpms and throttle positions...like depending on how i drive it, itll clank and rattle...my baby is in bad shape...=(
as soon as i have some extra money im going to buy a compression tester...
Old 09-18-2009, 10:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Spun bearing
Check your oil, a spun bearing will leave metal in your oil. Also you can drive the car with a spun bearing for only a little while. After running a some it will create a lot of heat and throw the rod.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-19-2009, 07:49 AM
Re: Spun bearing
i JUST chnged the oil a week ago, no metal.
must be something else...
thanks
Old 09-19-2009, 08:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Spun bearing
Does it sound like it's coming from the top end or bottom? Listen to it and rev to get that sound. Listen from underneath by the oil pan. Is it from the tranny?
Is it leaking any oil, like out by the trans or by the timing belt?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-22-2009, 08:36 AM
Re: Spun bearing
no oil leak, except the oil filter is a little oily on the outside, but thats from hitting it on a pothole a while back, it doesnt actually LEAK persay, not enough for the oil level to go down b4 the next change.
it sounds more like the bottom end...definately...
it just rattles like a bolt in a pepsi can at the beginnning of 1st gear usually is when it happens...like starting off...and also sometimes when i release the gas under mild/heavy accelration, itll do it when i let off the throttle...like theres a mixture off sound between the bov blowing and the engine knocking...
i wont know of coarse until jan. or so what the problem is, but id like to try and figure out what it is so that i might learn more about it...
