PCV Valve...
There MAY be a LOT less to my "oil burning" situation...I know someone mentioned it before about making sure i use a DELCO PCV valve..and sure enough i found out the one i installed many months ago is not! And many months ago just so happens to be the time i noticed i was burning oil lol! I know my old PCV was still working but replaced it anyway for some reason, but luckily i kept it so i'll have to find it and see if that works. I'm really gunna be kicking myself if that was it. Then i don't have a good excuse to mod/rebuild/replace the engine :-( not that i have the money anyway. As you guys know i've been running in circles finding out why the hell it does this so i'll keep you all posted and hopefully have a result in about 5 hours when i get home.
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
Re: PCV Valve...
That'd be good if it works, but I've been using Autozone PCV valves since the late 80s with no ill effects.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: PCV Valve...
Yeah it may still not be that good..And one more important thing to note. When i did the compression test, i noticed all of the spark plugs had a whitish-very light tan color. I heard this is good right? I guess this means i'm not burning a whole lot of oil, only when i idle like i said, which i now try not to do as much as I can. I would assume this means it COULD be the PCV because it can't "keep up" at idle but can at higher RPM. Like i said i'll post an update later today.
Re: PCV Valve...
when blow by crankcase gases get injested into the intake by way of the crankcase vent/ PVC this is usually the light brown deposits on the plugs..If you had bad oil rings you would see the black/oil residue. when the compression rings are worn or stuck you get the blowby condition like your symptoms are.. the pcv I get only the a/c delco..had trouble a long time ago..forget where I got it or who made it...getting harder to get good parts.. I said it before "make sure the crankcase vent system is working correctly" |
