90 2500 Speedo Woes, Reads Nothing, low or Erratic.
My big old pig just started this a week or so ago. Sometimes it works normal from startup but most times doesn't work at all. Other times it reads way low by 20 to 50 mph. The odometer works fine all the time. It is one of those arch type speedos is the best way I can describe it. If it is the cluster would a 88 Silverado K1500 direct replace it as I have an organ donor in the back field? Apologies for the cross post, I put it in the silverado section then noticed it should have gone here.
Re: 90 2500 Speedo Woes, Reads Nothing, low or Erratic.
My 450,000-mile '90 lost its speedo, odo, cruise control and HVAC fan when the third A/C compressor locked up. The serpentine belt took out the electrical connector on top of the compressor and that blew a 25 amp fuse that stopped the above-listed components. I've always sworn byu the indestructble Goodyear Gatorback belt, but this time it was TOO strong. A crummier one would have just snapped without damaging the electricals, and I always carry the tool and a (used) spare. Maybe you have a fuse that almost works, intermittently? More likely a connector or solder joint. Once you get the dash top off, try wiggling the wires or printed circuits behind the speedo. If nothing affects it, go ahead and swap. |
. strangely that was just a press in and go swap out which wasn't bad. ![]() ![]() ![]() :runar ound:
The vehicle speed sensor is mounted in the tailshaft of the transmission. Check it for normal operation as well as the wires to/from it for breaks, good grounding, etc.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
