Old 09-18-2009, 06:00 AM
ampig ampig is offline
Serpentine Belt Problem
I've got a 97 Cavalier with a 2.2 engine. I need to change the alternator but am having trouble with loosening the serpentine belt.This engine has no tensioner pulley - only an idler pully.
1) How do you go about loosening the serpentine using the idler pulley?
2) What size/type metric wrenches are required?
3) Do I need to take off the top motor mount which is directly over the front of the engine?'
4) What else do I need to know?
Thanks in advance
Old 09-18-2009, 07:42 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Serpentine Belt Problem
It has both a tensioner and an idler--- look closer-- much easier to access from underneath and through the wheel well-- use a 15mm wrench to unload the tensioner.....tensioner is below the power steering pump....
otherwise there would be no way to remove belt----unless you consider the new stretchy belt design found on the 2010 Camaro V-8 a/c belt-- which indeed does not use a tensioner...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 09-18-2009, 08:21 AM
I know that most of these engines have a tensioner, but this one does not. There is only an idler.
Old 09-18-2009, 08:44 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
you should see this around the center of the engine. It is the tensioner! If it does not move it is frozen (not uncommon) and needs to be replaced. They run about $60.
Old 09-18-2009, 10:11 AM
Thanks Airjer. Would you happen to know what type of tool I'll need and what size socket it requires?
Old 09-18-2009, 10:57 AM
Airjer_'s Avatar
Old 09-18-2009, 02:35 PM
So, the same size wrench is used on the idler pulley as on the tensioner. Thanks guys.
