Old 09-17-2009, 10:15 PM
gene5118 gene5118 is offline
won't shift into overdrive
My 95 Lumina with 199,000 miles on it will not always shift into overdrive. It seems to do it more when its first started for the day. I have changed trans fluid and filter regularly so I don't think its that. If is not shifting into overdrive, I have to stop the car , shut it off, then restart and it will then shift. Anyone else have this problem.
Old 09-18-2009, 07:28 AM
maxwedge maxwedge is online now
A990 racer
Re: won't shift into overdrive
This can be a shift solenoid issue or an internal problem, get is scanned by a trans shop for a proper diagnosis.
Old 09-20-2009, 01:29 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Which trans. does it have in it?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 09-20-2009, 07:58 PM
A990 racer
Should be a 4t60e.
Old 09-21-2009, 06:26 PM
yes it is a 4t60e. Shifts into OD 95 percent of the time. If you run it around alittle before going on the road it seems fine. Its when you hit the road immediately.
Old 09-21-2009, 07:45 PM
A990 racer
Until the temps reach a preset limit it will not see o/d, pcm programming.
Old 09-25-2009, 02:53 PM
If it doesn't shift into OD, it never will. The only way to make it shift is to stop, shut it off, restart, then it will be fine. Crazy I know.
Old 09-25-2009, 07:32 PM
A990 racer
A trans function scanner in the hands of a trans tech can look at internal solenoid operation and pcm commands to see what the issue may be.
Old 02-16-2010, 09:13 PM
Apparently something was just loose behind the engine. I recently changed the rear exhaust manifold and no more "no shifting into overdrive"
Old 12-19-2016, 07:54 PM
slingslingbinks slingslingbinks is offline
Send a message via MSN to slingslingbinks
I see this thread is over 5 year's old.
I know what Gene mean's.
I have the same problem with my 95.
I kick it in neutral, coast and turn the key off for 10 second's and fire it back up and there is overdrive.
Just had the tran's rebuilt after my no lock up and blew the front seal out problem i previously posted.
Talked to the builder and a new solenoid pack was installed and i even installed another body control module and i still have the problem.
Old 12-20-2016, 03:14 AM
Schurkey Schurkey is offline
Originally Posted by slingslingbinks View Post
Just had the tran's rebuilt ...
...Talked to the builder and a new solenoid pack was installed and i even installed another body control module and i still have the problem.
YOU do not have this problem. The guy who rebuilt the transmission has this problem. Take it back, tell him to call you when it's fixed.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 12-26-2016, 09:26 AM
j cAT j cAT is offline
I would not use that tranny tech again.
