Old 09-17-2009, 08:36 PM
brinkz brinkz is offline
another idle issue...sorry
ok i am new to the civic forum, so please be gentle. I have an 89 civic,1.5, auto with air. I couldnt find this specific problem. The idle is fine engine warm or cold, but as soon as i turn on the A/C the idle starts to rev up and down. Not crazy high or any thing, but enough to notice. And when I turn the a/c off, the idle returns to normal. No codes on the ecu, any thoughts. The Haynes dosent really have anything for this problem, so any help would be great.
Old 09-18-2009, 10:20 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: another idle issue...sorry
My first guess would be IACV - Idle Air Control Valve. It's on the back of the motor and regulates the idle. Since your ecu revs the motor up a little when the a/c is on the iacv has to adjust to that, and usually if it starts going up and down fairly quick it's because the adjustment gets to a point that it's out of the iacv's range and it can't compensate. At this point it just goes up and down trying to find the correct adjustment point, but never finds it. Might try adjusting your idle screw down a little.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 09-18-2009, 09:46 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
It shouldn't be the IACV since he has no issues normally, sounds like the PCM is having issues adjusting with the A/C on
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-19-2009, 01:51 AM
4G4D Store's Avatar
Ya, I just usually prefer to adjust stuff first before replacing parts.
Old 09-19-2009, 09:54 AM
Tony's Avatar
TLD Member #1
Same here, but it doesn't sound like a IAC problem, if it was, it would be all the time. Just got done fixing mine. Sounds like its possible the PCM isn't picking up that the A/C is on, or just isn't adjusting correctly for it. Couldn't really tell you a whole lot about it because I don't have A/C.
Tony
Old 09-19-2009, 07:51 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
i sort of agree with the 2nd post, just for different reason. ac takes power from engine, engine is old, pcm has to adjust by adding more power to the engine, my guess would be - by sending more air/fuel into it, revs go up, ac turns off - it all goes to normal, and so it goes.
i don't think there's anything wrong with the car. it's called AGE. i just turn the screw on idle limiter to jag it up higher some.
Old 09-19-2009, 07:52 PM
ukrkoz's Avatar
actually, general tune up should help in itself.
Old 09-19-2009, 08:35 PM
ok i will try all of that and report back, i have a spare ecu, so i will try it. And i will check the idle on the engine as well.
Old 09-19-2009, 09:43 PM
ukrkoz's Avatar
yeah, but it's not ecu. ecu is just trying to prevent engine from stalling. i think, it's just lack of power due to advanced age. that's why i said - maintenance/tune up.
