Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-17-2009, 04:57 PM
bboek bboek is offline
99 Suburban won't start
Suburban running fine, turned it off then it would crank but not start. This happened a few weeks ago then again today. A few weeks ago it started the started the next day after sitting all night. Fuel pressure fine. Mechanic thinks it could be ignition coil or module. Any other ideas?
Old 09-19-2009, 09:45 AM
j cAT j cAT is offline
Re: 99 Suburban won't start
what was the fuel pressure??? how long did the fuel pressure stay at the correct pressure with eng off key on ???
what engine is in it ???
bad ignition is not that intermittent,,,normally..fuel issues are..
Old 09-19-2009, 12:27 PM
I think you are right regarding fuel issues. I gave up and took it too the mechanic so I should know Monday. Not a cheap fix if it is the fuel pump. Thanks for your help.
Old 09-20-2009, 10:35 PM
laxman21's Avatar
laxman21 laxman21 is offline
Got a delphi unit from these guys for my blazer... less than half price from the dealer. Cost less to install than the dealer price for the pump.
https://www.partshighway.com/search....2&subcatid=161
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-21-2009, 03:58 AM
Jeremy-WI Jeremy-WI is offline
If it has the 5.7 or 7.4, how long ago was the distributor cap and rotor changed?
Old 09-21-2009, 08:18 AM
Cusser's Avatar
Cusser Cusser is offline
I use aerosol starting fluid to determine whether an issue like this is fuel or ignition related. If it starts, even for just a few seconds, after spraying in some starting fluid, then it's a fuel-related problem.
I just had my '94 Sub fuel pump changed a few months ago ($250), went out at 190K miles.
