Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-17-2009, 04:09 PM
Buckeye Guy Buckeye Guy is offline
Question Quick Questions on Spark Plugs and Wires
All,
Getting ready to attempt the dubious spark plug replacement on my 2002 Venture and gathering the components right now (I think I will be set with the procedure for getting at them from below based on the numerous posts here). My questions deal with the material.
I would like to go with OEM plugs, but the dealer will not give me a part number. The one I found that I "think" is correct is 41-101 (about $10 a piece). Can anyone verify this is correct?
The dealer wants $80 for OEM wires, but the Auto parts store says their Autolite "professional" wires are even better then OEM for $25 total. I thought I had read at one point that people were strongly recommending the OEM wires even with the extra cost. Has anyone had good / bad experiences that could point me one way or another?
Regards,
Pete
Old 09-17-2009, 04:37 PM
civic lx civic lx is offline
Re: Quick Questions on Spark Plugs and Wires
I always use www.autopartsgiant.com for looking up parts. It looks like you have the correct plug number 41-101 ($6.50@) and the GM wires are $53.00. Spend $99.00 and you get free shipping and no sales tax.
I have to say that I run Boshe Platnium plugs and some BWD Select wires on my 02 Olds without any problems.
Old 09-17-2009, 10:20 PM
wafrederick wafrederick is offline
Banned
Do not ever put Bosch plugs in a GM,do not last!I see Bosch plugs in a GM,they go in the garbage can and that is what they are worth for.I pulled plugs out of a blazer would not start and one cause was Bosch plugs which were brand new and installed AC Delcos.Install only AC Delco spark plugs in a GM.Do not rely on the $25.00 plug wire set,cheap is not always better and plug wires are this way.Go with the $80.00 set instead and replace the fuel filter also.It is part of a tune up and the most neglected filter to get changed.A plugged up fuel filter does put a strain on the fuel pump and will kill it.
Old 09-18-2009, 04:55 AM
shooter_va's Avatar
shooter_va shooter_va is offline
I usually buy all my parts from www.rockauto.com , they have a lot of OEM parts.
1998 Venture LS
2001 Silverado 2500HD, LT
1990 Cavalier
Old 09-18-2009, 12:02 PM
I looked at the Rock Auto web site and noticed that they sold both a 9726UU and 726UU, with the latter being $20 more expensive ($47 as opposed to $27). Does anyone know if the 726UU are a higer quality wire? It seems odd that they both come from AC Delco, but one is almost double the cost.
Regards,
Pete
