Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 09-17-2009, 02:00 AM
shawnsbroketoy shawnsbroketoy is offline
replaced timing chain but still flopping around
Hi i have a 95 22re that wouldnt idle and makes a bad noise from the chain grinding the valve cover and timing chain cover when you rev it to make it run so i checked the guides and everything was fine but valve cover had some wear from the timing chain so i replaced the timing chain and components with a kit, wouldnt you know it does the same damn thing.I messed around with the timing a tooth over here and there but nothing worked.i am mechanicaly inclined since it is a family trade but i am no expert.any advice as what i should do next would be greatly appreciated
Old 09-17-2009, 08:50 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: replaced timing chain but still flopping around
What exactly is it doing?
Old 09-17-2009, 07:36 PM
rhandwor rhandwor is offline
Where is the wear do you have end thrust and the pulley rubbing or is the chain loose and slapping the side.
Normally their is some adjustment for the guides.
Old 09-17-2009, 08:03 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
There is no adjustment on the guides of a 22R TC. There is a hydraulic tensioner, which would be replaced as part of the TC kit. The oil passage to the tensioner could be clogged, which would cause the old and new chains to have too much play and slap. Pull the valve cover and grab the TC to check for play and tension. And put the TC back on aligned right.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-17-2009, 08:05 PM
fasttoyotapu fasttoyotapu is offline
Send a message via AIM to fasttoyotapu Send a message via Yahoo to fasttoyotapu
There is some adjustment room on the timing chain guides. by any chance did you replace the chain only or did your kit include the guides / tensioner? If it did not it may be you tensioner. Another possibility is your head may have been machined in the past. a simple measuring check should determine this. only problem is that you will have to open her back up and thats a pain and more gaskets. if it has been machined you will need to get a shim for your head to make up the differance. I hope this was helpful.
91 Toyota Pickup - Lowered, Racing Suspension, 96 Toyota Supra 2JZ-GTE Engine w/ 6 speed man. trans. - Crashed racing SCCA - RIP
86 Toyota Pickup - 4x4 - Chevy 305 Engine - Rest stock toyota
Current Project - 90 Toyota Bedless Pick-up - My new mini - Currently Lowering and finding a new bed. The flat bed went to my dad's truck. Merry Christmas Dad!!
Worked:
Doxon Toyota - 4 years
Bowen Scarff Ford and Scarff Ford- .5 years
Old 09-21-2009, 01:41 AM
thanks for the help.the kit included chain,tensioner,crank&cam gear,guides,gaskets.i was wondering could it be electrical.when i had the disributer out and the ignition turned on,the coil would make a zapping or shorting noise when i spun the rotor.i am not sure if that is normal or not.
Old 09-21-2009, 08:06 AM
Run the vehicle at night and observe the coil for arcing. I would fix this problem first. Normally if you look closely if the chain is rubbing wear will be noticed.
Old 09-21-2009, 08:54 PM
Normally it's not a good idea to play with the cap and rotor while it's hooked up without the plugs hooked up and grounded since it really screws with the coil among other things. It might be a good idea to see how the whole ingnition setup works when it's all hooked up correctly. If it still arcs/pops, definately do the check as stated above...
Worked:
