OUT: temperature light and compass near the top of the dome light not working
please tell me what fuse , controls the compass in my 05 tacoma ..it wont light up and want to check it first ...I dont have owners manual ..I know there a diagram under the fuse cover ......... the 2 dome lights work !
any idea what I can check ? thanks .... joe .... las vegas |
Re: OUT: temperature light and compass near the top of the dome light not working
________________________________________ Problem: Overhead Compass/Temp Doesn't Work Tools Needed: Philips, torx bits, soldering iron, solder Steps to Fix: 1. Open sunglass holder 2. Remove screw holding console to ceiling 3. Grip and pull down on the front (windshield-end) of the console. It will take a bit of pressure for the clips to release. 4. Unplug electrical harnesses 5. Ensure the you still have 2 metal clips attached. If not, the missing one will be laying in/next to the clip-hole. 6. Remove the 3 Torx screws holding the display/board 7. Unclip the plasic cover from the board. Be careful. They break easily. 8. Locate the '510' resistors and look for disconnection. Mine was very easy to see. 9. Press down resistor and solder broken end. I chose to solder both ends of both 510s to make sure I won't be back in there. 10. Reassemble. It may be worth testing before you snap the clips back into place. Last edited by Percon; 11-20-2009 at 03:59 PM. |
wow , that worked great !!!
very happy and fixed it for free !! thank you so much !!! joe in las vegas |
Your welcome!!!
