Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-15-2009, 10:04 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
Mustang turning noise
Hello, I have a 98 mustang 3.8 with 65k. Recently when turning into a parking spot, drive, etc, it is making a clunking noise. It comes from the passanger side. what should I look at first?
Thanks Derek
Old 09-15-2009, 10:06 PM
az_jobu az_jobu is offline
Re: Mustang turning noise
check the strut mounts, also jack up the front end and shake it down for loose parts
Old 11-12-2009, 11:37 PM
OldSVTGuy OldSVTGuy is offline
You might check to make sure that the bolts holding your steering rack on are tight, too. Sometimes they "pop" when just a little bit loose. Also, as noted before, check for loose parts - outer tie rod ends, ball joint, etc.
