Old 09-15-2009, 06:47 PM
indebt94 indebt94 is offline
bunch of problems
my 90 civic si with b16a has been refusing to start and run for a long time now. i cant find the frequently asked questions area, although i see people talking bout it a lot so here it is. now my main relay is buzzing, before the light on my ecu was solid red. im sure next time i go to the garage it will do something else retarded. ALL I WANT TO DO IS RIP IN MY HATCH AGAIN HELP
Old 09-16-2009, 04:47 PM
Re: bunch of problems
ssoory for my noob status, found faqs and why is my main relay buzzin and red light solid on the ecu. has anyone had this problem before?
Old 09-16-2009, 10:20 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
this compilation will help you a lot.
http://www.tegger.com/hondafaq/faq.html#mastertop
main relay is not that expensive.
took me only about 20 minutes to replace it on 91 civic.
Old 09-20-2009, 02:55 AM
i have a new main relay as well as about 5 spares from the junkyard. i been swapping them in and out to no avail. same problem. also the check enginr light on the dash seems to be on allthe time but no codes are flashing on ecu.
Old 09-20-2009, 06:33 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
sounds like you missed a ground or something... check the one on the thermostat housing... that would be my guess
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
Old 09-21-2009, 11:43 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Ya, definitely sounds like a ground issue. Make sure you have both the ground on the head to the chassis and the one for the starter on the passengers side. If you are missing one of those then you will get some weird issues like that.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 09-28-2009, 03:37 PM
so. i also agree that it sounds like a ground problem. all the grounds are there and unchanged from when the car ran. i found the other night while troubleshooting that when i hit the brake pedal the red light on the ecu goes out, something ckicks in my seatbelts and some beeping goes off. so i did some main relay swapping and now the red light does not stay red, it flashes as if normal when the key is turned on. car still wont start though. whats the brake pedal have to do with this? help
Old 10-04-2009, 01:53 PM
87e-at 87e-at is offline
sound haunted you wouldent catch me driven it i have firm beliefs in cars having feelings iv had some weird shit happen
