Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 09-15-2009, 01:30 AM
QCubed QCubed is offline
98 Windstar wheels & tires on 99 Cavalier
I'm thinking of putting on my 98 Windstar wheels and tires on my 99 Cavalier. With some research I found out the bolt patterns for the windstar are 5x108, and the hub size is 63.9mm. The bolt pattern for the Cavalier is 5x100, and the hub size is 57.1mm. I have no idea what all this means. Please reply and let me know if what i am thinking of is do-able, and what issues I might run into, and the possible solutions to those issues. Thanks all for all your terrific input on this matter.
Old 09-17-2009, 02:36 PM
Re: 98 Windstar wheels & tires on 99 Cavalier
BTW: I should mention that the Windstar tires are 215/70/15 and the factory tires for the Cavalier are 195/65/15.
Old 09-17-2009, 03:28 PM
manicmechanix manicmechanix is offline
What that means is the lug bolt circle diameter and the center hub hole is bigger on the Windstar wheels. Even if you could get the Windstar wheels to physically to fit on the Cavalier, it would not be a proper fit.
These Windstar tires are quite a bit taller than your Cav's and it's going to raise your ride height. The wheel offset might be different too which will also alter your steering scrub radius. Bottom line is I would not put those wheels and tires on a Cavalier.
The Following User Says Thank You to manicmechanix For This Useful Post:
QCubed (06-01-2011)
Old 09-17-2009, 09:21 PM
Manicmechanix: Thanks to you I now know not to try this. And, other future readers of this thread will be educated on the matter too. Thanks again!
