Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-15-2009, 01:28 AM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
'93 3.9L intermittent cut out under load.
I have a 1993 Dakota with a 3.9L. A couple hundred miles ago it started cutting out around 2200 RPMs and kind of sounding kinda like a backfire. The engine does not die, but the whole truck jerks for an instant. A second after this happens, the speedo jumps once. If I try really hard I can make it do it eventually. But is otherwise inconsistent. THERE ARE NO CODES.
I am an ASE Master Mechanic, so I have a general knowledge, but most of the vehicles I work on are Fords.
I have already replaced the following items in the last 5,000 miles, because of other problems or in an attempt to fix this:
Plugs, Wires (I hadn't changed them since I got the truck)
Distributor, Cam sensor, cap, Rotor. (This fixed a dying in the winter problem, with a loud noise from distributor)
Both coolant sensors behind thermostat. (Also caused me dying problems)
Throttle position sensor. (Attempt to fix cut out)
Crank sensor (Last resort to fix cut out)
Old 09-15-2009, 11:29 AM
jpb53 jpb53 is offline
Re: '93 3.9L intermittent cut out under load.
Ck Chrysler TSB 18-08-93. If the dist and drive gear ck okay you might redo the dist indexing.
Old 04-07-2011, 12:08 PM
Just an update, I gave in and had the dealer look at it. The distributor drive bushing was bad. Runs great now, (still can't get above 17 mpg.)
