Old 09-14-2009, 01:44 AM
jsnevets jsnevets is offline
Power Steering Whine
The whine from my power steering pump has gotten progressively louder over the last month. It used to whine a little when I would turn. Now it whines with no steering wheel input. It's kind of odd but if I apply slight pressure on the steering wheel to the right or left the whine will go away. But if I turn the wheel further the whine comes back. There are no leaks, the reservoir is full, and the steering seems to work fine. The noise is just getting worse. Very annoying now. Even though there haven't been other problems than the noise, I assume the pump could still die at any time?
2001 Grand Prix GTP S/C
Old 09-14-2009, 02:30 AM
91 bird 91 bird is offline
Re: Power Steering Whine
the pump is going to go. sounds like you dont have much time left. a week, a month, 2 months. hard to know.
Old 09-14-2009, 03:32 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
I agree. It sounds like it's time to pick out the plot for your pump.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 09-15-2009, 08:24 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Hmmm, mine sounds like that too only it has not gotten worse. I have suspected my pump also, but swapping it out did not fix my issue completly unless I have installed a second bad pump.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-16-2009, 08:12 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The pumps on these cars seem to be noisy by nature. Mine is making noise also, although only intermittently and it's a Delco pump and I flushed out all the old fluid because it was pretty dark. Steering works perfectly, it just growls occasionally.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-16-2009, 08:35 PM
tblake's Avatar
In God We Trust
Mine too Rich. Makes sort of a whine noise that usually is worst when its initially started. It goes pretty much completly away when its warmed up, and I have no fluid leaking and it is still a nice clear tan color. I'm stumped, so I'm just living with it.
Anyone install a brand of pump that does not make noise?
Old 09-16-2009, 08:51 PM
00GTP4ME's Avatar
I had mine replaced shortly after getting the car and it doesn't really whine. I don't know what brand it is because I didn't buy the part or anything - the shop handled it all. It started whining pretty bad once but that was because I was a slacker and didn't check the fluid for a very long time. Once I topped it off the sound went away.
