Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 09-13-2009, 11:38 PM
Persistent One Persistent One is offline
oil pump replacement
can i replace my oil pump with the engine still in? if so how?
Old 09-14-2009, 05:31 AM
rhandwor rhandwor is offline
Re: oil pump replacement
Normally you have to pull the bolt in the motor mounts and raise the motor about 4 inches. Put a 4x4 blocks under the mounts. Watch close as you are picking up the engine you don't break anything. Loosen transmission mount bolt also.
Old 10-18-2009, 03:38 PM
wafrederick wafrederick is offline
Banned
The answer is no and the book says to pull the engine.
Old 02-06-2010, 09:27 AM
Hmmm! Hmmm! is offline
Actually, yes you can! Have done it but you have to pull the distributor because it will bend before you get the engine high enough.
Old 02-06-2010, 10:42 AM
mechhound mechhound is offline
Buy a Haynes repair manual and follow the step by step instructions.
What is the problem that makes you think the oil pump needs replaced?
Old 02-06-2010, 08:34 PM
Davescort97 Davescort97 is offline
Escort guy
He probably has low oil pressure. Probably the bearings.
Old 02-06-2010, 08:44 PM
Davescort97: It could be any number of things actually, up to and including simply having sludge in the bottom of the oil pan...been there on that one myself.
