Old 09-13-2009, 10:26 PM
Wycked1 Wycked1 is offline
91 Buick LeSabre
I just bought a 1991 Lesabre with low mileage for a real good price. The issue it has is that with the fan on high no air comes out the vents, or very little as in almost none. Has anyone had the same problem? What was the fix? BTW the fan is running just no air into the cab. Thanks
Fred.
Old 09-13-2009, 10:31 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 Buick LeSabre
Usually this is caused by a vacuum leak either at the manifold, check valve or reservoir mounted on the firewall. Do you have air flow through the defrost vents?
Old 09-14-2009, 09:39 AM
Just minimal air thru the others as well. The damper seems to switch over.
Old 09-14-2009, 11:51 AM
HotZ28's Avatar
AF Moderator Elite
Sounds like you may have a clogged evaporator. Do a search for "evaporator" and you will find some good threads on the subject. Click Here & Here for a couple of them.
Old 09-15-2009, 01:25 AM
thanks for your help I'll let you know what I find.
