Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-13-2009, 04:35 PM
bronco1960 bronco1960 is offline
will not start
put on head gasket know it will not start pontica bonneville 98
Old 09-13-2009, 09:53 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: will not start
Do you have good spark & fuel pressure?
Old 09-14-2009, 08:19 AM
Re: will not start
yes it has good spark and fuel pressure we check the injection by put plastic bags around the ijection and turn the motor over
Old 09-15-2009, 08:25 PM
HotZ28's Avatar
AF Moderator Elite
Re: will not start
What was the problem that lead you to replace the head gasket? Having a blown head gasket is on this engine is very rare.
Old 09-16-2009, 07:27 PM
Re: will not start
number 6 cylinder low compession
Old 09-16-2009, 09:21 PM
HotZ28's Avatar
AF Moderator Elite
Re: will not start
Do you have good compression on all 6-cyl now? All vacuum lines connected and no leaks?
The injectors may be firing, but what is the fuel pressure?
Old 09-18-2009, 08:49 AM
Mickey#1 Mickey#1 is offline
Re: will not start
Double check the routing of the spark plug wires. If coolant got into the cylinders then you may have to replace the spark plugs. Check the metal tube that goes to the EGR valve for cracks. They break quite easily & can give you a huge vacuum leak.
Old 09-23-2009, 07:02 PM
Re: will not start
fouled spark plugs was the problem Thank for the help
fouled spark plugs was the problem Thank s for the help
