Old 09-13-2009, 03:23 PM
bikernut's Avatar
bikernut bikernut is offline
Steering wheel noise
I know this is a problem with the new GM truck vehicles (2001-?) but what can be done to get rid of the noise and bump from the steering wheel. I heard that GM has about 35 fixes out that doesn't cure it, can any of you tell me what you have done to get rid of this problem. My truck is a 2005 Duramax equipped Dually 3500 crew cab 4X4. thanks
3500 Dually Member # 252 and Damn proud of it
2016 GMC Denali Dually Duramax w/Automatic
6X6 (rear tires are dual) ..
enough power to pull the old guy
from the P !!ss Pot
2007 KZ New Vision 41kgx2 Toy Hauler
2 Harleys (2015 FLHTCUTG and 1995 FLTCU)
1987 Trans Am GTA (with only 19,783 mile)
1992 Chevy S-10 4 dr, 4x4 Blazer
03 GMC 3500 Dually
Old 09-13-2009, 04:26 PM
jyount jyount is offline
Re: Steering wheel noise
Take out the intermediate shaft loose from your steering column ( one bolt under dash) and run the shaft in and out and put it back on, will fix it for another few thousand miles. I used to work at the dealer, we replaced em, then we cycled em, then we took em out and filled em up with grease....yada, yada, they all worked, for a bit, then they would do it again. GM won't fix it, apparently splined shafts in this location suck for noise, cause they have had a couple different shaft makers, and they all do it. Once the slip shaft get dry of lube they rattle and you feel it in the steering wheel. Wont hurt it, but it is annoying to say the least, no fix, just grease it up and forget about it till it does it again....
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 09-14-2009, 04:42 PM
bikernut's Avatar
thanks for the info and congrats on being almost a JD certified tech. I was 20 years ago an ASE certified tech but went to a better paying job with more time off.
from the P !!ss Pot
03 GMC 3500 Dually
Old 09-15-2009, 07:46 AM
intimadatorsquizz intimadatorsquizz is offline
Dorman redesigned them it's a totally different shaft and will fix the issue
https://www.dormanproducts.com/cgi-b...rid=0x004d51c1
