'99 regal power windows
i have a 99 regal that when you try to roll the driverside window down the switch buzzes. also none of the other windows will work. all were working untill about 2 weeks ago then some times they would stop untill you either opened the drivers door or helped the drivers window down.
3 days ago my step dad bumped a telephone pole with the driver door and crunched it. now the master switch does not light up or buzz. i tried a new switch at autozone, it lit up and buzzed but wouldnt move any windows. now i'm at the point where i took the driver panel off and wedged the window up. but the pass. window is still down. is there any way to juper the wiring plug and trick the passenger window into rolling up? its a good door still and i dont want to hillbilly it. |
Re: '99 regal power windows
The drivers side window actutator/drive motor could be damaged causing a load down of the electricals. Disconnect the motor and see what the other windows do. Also, the driver's side master switch provides 12 volts to all the other windows.
drivers window is disconected at the motor. only 2 wires going to the motor.
the pass window switch has 7 wires. i was hoping to either brigde 2 wires at the switch or run 12volt straight into the switch harness. i just dont know which wires to use. |
