Go Back   Automotive Forums Car Chat > GMC > Commercial Trucks
Old 09-12-2009, 11:02 AM
Eddy1 Eddy1 is offline
Aircondition problem, 95 Diesel suburban
My compressor died so I took it in and had a new compressor and dryer installed and recharged, I got a call from the shop that the pipes inside the engine compartment were frosting over and no cooling going inside the cab. He could not figure it out and put my truck back to how it was, what do I do from here? The mechanic thinks something in the condenser or in the cab is clogged,
how can this be flushed out?
I am in Los Angeles.
Old 06-08-2014, 07:18 AM
eladrgl eladrgl is offline
Re: Aircondition problem, 95 Diesel suburban
If the pipes are freezing over, you have a blockage in the system. Ask them if they installed a new orfice tube.If they did not this is probably your problem.
Old 06-08-2014, 08:40 AM
DeltaP DeltaP is offline
They should have called you before the compressor and drier were replaced advising you of debris in the system and the need for solvent flushing and a possible condenser replacement.This would have been evident when they removed the original O-tube.
