Old 09-11-2009, 01:45 PM
[email protected] DKLATU@AOL.COM is offline
1996 Chevy Blazer 4wd dies on road
1996 chevy blazer 4wd car just up and dies on the road replaced battery and ignition module help
Old 09-12-2009, 08:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1996 Chevy Blazer 4wd dies on road
Any check engine lights/code?
You need to check fuel/fuel pressure when it dies and for lose of spark.
To be able to help you post back info and results of spark and fuel pressure test.
Also any codes.
MT
Old 09-12-2009, 11:40 AM
Blue Bowtie's Avatar
Registered Offender
After all those checks, you might consider asking the aliens for help, since you're so close...
More information might also be helpful. Does the starter operate/engine crank? If so, can you manually provide fuel or starting fluid and get a brief run? Does the engine even attempt to fire?
