Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-10-2009, 09:33 PM
ice745 ice745 is offline
AF -Advisor
Roadside - Stuck Lug Nuts
It's happened to me on multiple occasions where my lug nuts will get stuck trying to take off a wheel. Usually it requires taking it to the shop to replace the affected wheel stud.
I understand this is usually caused by shops using a impact wrench to thread the lug nuts. However, my question is not about the cause. I was wondering if I were on the side of the road with a flat tire and I experience this while trying to change the tire, what is the best course of action?
In my experience continuing to force the lug nut off with a tire iron either results in flattening the threads on the stud (very noisy), or just snapping the stud in half. On a car that normally has five lug nuts, how many can I risk damaging before I should just stop and call a tow truck? Mind you this is just to get me home, and to a shop the next day - I would not plan on driving with lost lug nuts for an extended period of time.
Or would I be better off (both monetarily and safety wise) just calling a tow truck as soon as any lug nuts appear stuck?
Thanks for any tips and info on this problem.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 11-15-2009, 06:54 PM
nmikmik nmikmik is offline
Re: Roadside - Stuck Lug Nuts
Not sure if the cause of the thread damage is correct, but to address your question, I'd call the service before attempting taking off the wheel. This way it's their responsibility if it gets stripped and I am sure they'd have a trick or two on how to avoid that. If you get the AAA with a good plan it should cover at least three service calls per calendar year.
As far as how many lugniuts is safe to "loose" i'd say on the 5 lugnuts configuration probably 2, but it more depends on how far you have to drive home and at what speeds. I am almost positive that you could get home from couple of blocks away even on two lugs slowly, but would not be able to get on the freeway (and stay there) with only two out of five...
I used to live in Wisconsin for 11 years and I recall that after I started using the anti-seize grease (i am still using it on all my cars even though it's absolutely unnecessary in SO Cal) all my stripped studs/lugnuts problems disappeared. Try that & see if it works for you.
2014 Camry LE Hybrid - 19000 mi
2014 Chevy Spark EV - 5000 mi
2014 Chevy Spark EV - 3500 mi
2002 Lexus LS 430 - 105000 mi
2001 Volvo S40 1.9 T - 140000 mi
Old 01-04-2010, 04:22 PM
RT Jam RT Jam is offline
Fix the source of the problem. Make sure the lugs are torqued down correctly. Most cars are around 100 ft/lbs. That can easily be removed with a proper wrench. Oh and what comes with the car is not really a proper wrench. Go buy a 24 or 36" power bar and a 6 point brand name socket.
When working with hand tools, make sure you loosen the nuts before you jack up the car.
65 Plymouth Belvedere
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
00 Buick Park Avenue
Old 01-04-2010, 04:54 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Excellent post and information here, but I just want to correct a couple of things.
Originally Posted by nmikmik View Post
N This way it's their responsibility if it gets stripped .
It's not their responsibility if its stripped or broken upon removal, because it's a pre-existing condition.
Originally Posted by RT Jam View Post
Most cars are around 100 ft/lbs..
This is a bit too tight. The highest recommended torque I have ever seen for cars and light trucks is 80 ft.lbs. But most cars are a bit less..... 60 - 75 ft.lbs.
Check your owners manual, it will often show the correct torque.
It's important to use the proper torque and no more, to reduce the risk of damage or warping for rims and rotors.
Old 01-04-2010, 08:32 PM
Not sure what kind of cars you've been working on but it sounds like micro cars like Geo Prism but most cars are around 100 ft/.lbs.
I'll just like a few. Everything from Chevrolet that is not actually a Japanese car from 1987 to now and most every Chevy before that.
Every Chrysler is 90-110 ft/lbs. The lowest Ford is 85, everything else is 100ft/lbs.
Anyways the 100 is really mentioned to show anyone with a powerbar car undo at the side of the road.
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
