Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-10-2009, 08:38 PM
rhandwor rhandwor is offline
Mitsubishi Eclipse 10 point bolt
When doing a clutch job 10 point bolts were encountered. When a 12 point socket wouldn't fit an air hammer and a sharp chisel was used to bump them so they could be removed. They appear to be 13mm size. I counted the points and only 10 were observed. New bolts were obtained at a hardware store.
Does anyone know of a supplier for a 10 point socket that fits these bolts?
Old 09-10-2009, 09:41 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Mitsubishi Eclipse 10 point bolt
Why wouldnt you just replace them with a standard 6 or 12 point bolt?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 09-10-2009, 11:17 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Never heard of this. What motor were you working on?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-05-2009, 07:56 PM
New six point bolts were used on assembly.
Old 04-28-2010, 02:34 PM
ShadeTreeJack ShadeTreeJack is offline
Did you find the 10 point Sockets? I am about to replace a clutch in a 2001 Eclipse. Any advice?
Old 04-28-2010, 03:52 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Just follow the same steps used if you cant find a 10 point socket?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-28-2010, 07:06 PM
I mailed a bolt to a specialty tool manufacturing. I got an email stating they were made but not stamped. This was last week so they would be heat treated after stamping. I expect them on the market at any time.
http://www.tooltopia.com/ Search AST7409 Sears and Napa sell some.
A 14mm tool like this can be installed on the bolt.
Old 05-14-2010, 07:07 PM
I got my sample socket today its a Vim V10PT. Its a 12mm 10 point 3/8 sq drive. I would loosen with a long 3/8 ratchet and switch to an air ratchet.
http://www.vimtools.com/ Click on picture to get to the site. I checked today and it wasn't listed. Its made in the USA.
AST,SPC69330,and JTC sell a 14mm 1/2 drive 10 point. According to Koken its a 14mm, JTC 20mm,SPC 5/8 I measured mine with a scale and their all the same size.
Vim was manufactured to fit a bolt I mailed them. The others I mentioned fit a Honda.
Not all Mitsubishi use a 10 point some may have either a six or 12 point. Count the points before buying a socket.
Contact Vim if you need one in a hurry.
http://www.vimtools.com/store/page19.html end of page
Old 05-29-2010, 06:22 PM
Remember some clutches are modular.
http://www.partsgeek.com/mmparts/clu...i/eclipse.html
Scroll down to Sachs Modular clutch. Look closely at picture after you click on it.This type is more likely to use 10 point bolts. Use access panel unbolt six 10 point bolts and then pull transmission.
Opening in bell housing the flywheel bolts up on the back of the flywheel not the front like a normal clutch.
http://www.vimtools.com/store/page19.html Scroll to last item on page.
Old 05-29-2010, 09:28 PM
Thanks. I have the car up on jack stands and most of the bolts sprayed with PB blaster - especially the exhaust, which looks like the first thing that needs to come out.
Old 06-07-2010, 07:51 PM
How did the job go did you need a 10 point socket?
Old 06-26-2010, 08:05 AM
after a search locally, I bought the 10-point socket from Vimtools. they shipped itpretty quick. thanks for the link.
I have the car all back together. Now, the cluch won't disengage. The pedal does not feel like the hydraulics need to be bled, but I may do it anyway. The lever at the bell housing looks like it already in the disengaged position, I may be bottoming out before I get disengaged. I know I installed the clutch and throw-out bearing according to instructions, but this makes me question that. like I should have put the dampersprings toward the engine, not trans ??? like the directions said to.
Old 06-28-2010, 08:29 PM
Well after letting it sit for two days while I started a head gasket on a Neon, I decided to look into the access holes. I could see the clutch but not the throw out bearing and lever. I pulled back on the lever and all of a sudden it was in the right position, I put the slave cylinder in place, bled it and now everything seems fine. I have no I idea what was wrong. anyone want to buy a good used 12mm 10 point socket, only used once!
