Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 09-10-2009, 02:50 PM
discnik discnik is offline
Eating O2 Sensors
2002 Elantra. In the last year this vehicle has had three downstream, (After Cat), O2 sensors put in it. The last sensor caused the ECM fuse to blow causing a crank but no start condition.
Has anyone else had this problem with theirs ?
Also in the wire loom going to the ECM there is oily fluid in it but cannot find the source of the intrusion.
Any ideas ???
Old 06-13-2010, 11:50 PM
smithers.eric smithers.eric is offline
Re: Eating O2 Sensors
Have you tired checking on the cat to see if its eithier stopped up or if there is a blockage somewhere along the exhaust to prevent it from breathing and thus causing to burn the O2 sensor?
Old 06-17-2010, 08:13 AM
Jrs3800 Jrs3800 is offline
What kind of O2 sensors are being used for the replacement?
Old 06-17-2010, 08:35 AM
ricebike ricebike is offline
i think you have a wiring problem, not the o2 sensor problem
the trouble codes that gets triggered can be either the sensor itself or the wiring
